Man of Honour
- 13 Nov 2009
- Northampton
Due to wanting something new to play with I've decided I'm going down the W/C route, however due to outlay on the rig initially I skimped on the case as have the Asus ta-861
I've measured up etc and sure I can get a rad in the bottom no problems, will need to get some feet to stand it off the desk a bit though.
The question is whats the best way of cutting the holes. i'd rather it be using a hole saw as I already have an arbour and an assortment of sizes. Thge only issue im having is the fact that I've found a template from AC Ryan and they show a square cutout rather than just circular holes, would this affect performance at all?
and secondly what size hole saw would be best fit, but giving me a couple of mm to play with to file and get a nice edge
