Holiday & Travel Charging DSLR Batteries
20 Sep 2005
Wilderness of ESSEX
Hi,
has any one used this or some thing like this;
Neewer® USB Battery Charger for LP-E6 Rechargeable Battery for Canon EOS 5D Mark II III 5DS 6D 7D 60D 60Da 70D 7D Mark II III
The out put power seems to slightly more than the standard mains powered canon charger !
If the above is reliable I will certainly get one for holiday for traveling light.
many thanks
T
Snap !
Bought them a week ago.
It works as it should, it even has a 4 level/step LED showing it is charging. Basically, it lights blue when it is charging, when it is full, the blue light goes off. I also got that 4 port USB so I can do both the Canon and Fuji at the same time. I normally have enough battery to get me through a wedding, in fact, I have enough batteries for 2 back to back weddings but you never know where it might come in handy, particularly, I can charge it in my car with the USB cable or charge using a Anker battery.
I've got two of the Neewer chargers for my Olympus batteries, and a bunch of other Neewer stuff. Build quality on all of it is acceptable, and they do the same job for way cheaper.
