Just one if they’re all interlinked
You have 2 choices. You can either install it instead of a detector base and run an alarm cable to the panel or if your alarm panel is being installed near your fuse board (most are) install the relay base near your panel and get the cover for it. I would also look at the version with a battery
Yep pretty muchI have an existing wired alarm with 4 PIRs and two door contacts installed 6 years ago My fitter is due to come for the annual service next month. If i bought the texecom kit would it be as simple as swapping the panel, keypad and adding the wifi unit and just keep the existing cabling and PIRs?
Yep pretty much
Regarding the bell though I personally always prefer wired. Not a massive fan of the Texecom one though as I have had a fair few leds go. I use pyronix deltabell x with the light pad. Makes the house less appealing to a scum bag because it’s obvious you’ve got an alarm
Yes 8 Core is fine for everything wired. How many zones are you having in total both wired and wireless?
Have you allowed for the link between your smoke detectors as well? That needs a zone5 Wired zones (4 off the main control panel and 1 off one of the wired keypads)
initially 2 wireless door sensors but with the ability to add further
@pommy02 What's your thoughts on this diagram, this is how I've understood it from the Installation manual
I was about 10m short of cable to run the bell but everything else is run, I'll decide this week whether to get another reel or just opt for a wireless bell.
