Im going to be renting a one bedroom flat, and would like a multi-room audio setup.
I was thinking 4-6 units overall to over the entire flat, all playing the same music.
It has to be cheap (sonos is a no-go!)
It has to be neat (no wires trailing about the place)
What would you suggest?
(budget £300-500)
Ive looked at:
- Sonos - nice and neat, good connectivity options, far too expensive
- Chromecast audio - cluttered as it needs to be hooked into other speaker systems (which I dont have), but it is cheaper (factor in that I'd need to buy speakers too)
- bluetooth speaker - nice and neat, fits within the budget - but I cant be bothered to carry it from room to room...
- google home's - nice and neat, but the "Max" is almost the same price as the sonos - no-go
UPDATE: landlord has OK'd ceiling speakers - so that is now a possibility
(budget £300-500)
Ive looked at:
