Home automation Android
10 Jul 2006
I have a Google Home + Chromecast but every so often I want to fallback to an interface in my hands to control volume etc...
Im struggling to fine anything that will give me on screen buttons for controlling Chromecast volume in a dashboard interface. I can use the Google Home app but its too many clicks to get to controlling the volume as an example.
Any suggestions?
There's a setting in the Home app that allows a constant notification for controlling media playing through your Chromecast. Turn that on? :confused:
It does, but if you click on the notification it takes you to the device screen so you can control volume etc. - certainly reduces the number of 'clicks'.
Don't bother, you're wasting your time. If you are try to make your life easier, don't try to replace a remote with physical buttons with a tablet. It will not make your life easier....
Agreed. If only my Harmony had voice control for Sky Q and Prime...
