Home cinema - Projector, PS4, what else?
11 Feb 2004
UK
Can anyone provide some advice on what else I need for a home cinema setup?
I'm hopefully picking up a projector tomorrow and I also have a PS4 for the Bluray, streaming and a bit of gaming. However, I need to know what else is required. Can I just get a 5.1 speaker system and plug this directly into the PS4? Or do I need one of those AV receivers? Does the PS4 plug directly into the projector or does this also need to pass through a receiver? I could do with a diagram or something. :confused:
Any help and also recommendations on kit would be awesome. Cheers.
I have a PS3 and projector.
To connect up:
- If you have an AV amp, connect a HDMI cablem from your PS3 to the AV amp. Then a second HDMI cable from the AV amp to your projector. Job done
- If you're using a non-HDMI capable AV amp, connect the PS3 directly to the projector using HDMI, then a digital (optical SPDIF) from the PS3 to your AV amp
Hope that helps.
