Home connection check (diagram included)
1 Dec 2004
S.Wales
OK, im just about to implement my firewall at home.
Its a SonicWall TZ150, and im using it alongside my Netgear DG834GT.
Im planning on using the DG834GT as an access point (until I get a new dedicated access point), then all the WLAN traffic can go behind the firewall as apposed to infront of it.
Please check diagram, im 90% sure this will work but just want some eyes to check, only thing im not sure about is the laptops, they are currenty using wireless atm, would I have to increase the DHCP pool range on the netgear to 3 or 4 addresses, or would I have to do it another way?
Check diagram.
We currently have a customer using a similar config to this exept they dont have WLAN users, reason im doing it this way is because I have only 1 static IP address, so the netgears firewall is going to either be disabled, or will be enabled and forward all traffic to the sonicwall, the sonicwall will then be doing all the rule based shizzle.
Thanks all
I just noticed a mistake, on the sonicwall firewall, the WAN IP will be 192.168.1.2, the LAN ip will be 192.168.1.3 and the DHCP range will start from 4.
So chuck the LAN on 192.168.2.0/24 subnet?
What about the laptop users? where would they be getting the IP addresses from (Until I can get a dedicated access point behind the firewall)?
What I'd be inclined to do then is configure multiple VLANs on the router, with a default gateway of the sonicwall. This way you have a Wireless vlan that forces the traffic through the sonicwall before back out into the WAN vlan of the router.
You would probably find this a lot simpler to set up using a router designed for SoHo use. My suggestion would be the Netgear DGFV338. Just one box that will do the IPsec VPN and all the Wan/Lan firewalling you may want.
TBH the only reason im implementing a dedicated hardware firewall onto my network is because I aqquired a TZ150 through work, its just sitting at home at the moment doing nothing. I want to make use of it tbh, I know it can be done through the Netgear using the config I have above as have set-up a network with a similar set-up, only difference being no WLAN and my network has this.
My DG834GT has a built in firewall which I can leave turned on, or disable, but the firewall on the SonicWall is more advanced hence why im wanting to use the Sonicwall.
