We've just bought a new house, it's a two bedroom, London Terraced house. We'll likely be moving in around 4-6 weeks time. I'm taking this opportunity to network the house up before fitting new carpets and such.
I wanted advice on my 'plan' for the network rollout.
Locations & Devices
Ground Floor
There are three rooms downstairs; the lounge, diner, and kitchen, in the middle of the house are the stairs (between the lounge and diner).
There is a small cupboard under the stairs which host the electricity fuses for the property, I want to distribute the network from this point, alternatively there is also a small cupboard above the stairs on the first floor that could be used.
The lounge will host the modem for our internet (BT Infinity 2), I plan on using an ethernet connection to route this to where I will distribute the network.
The lounge will also host a TV, Apple TV, and PS3, so I plan on using 3-4 ethernet connections to route to this location.
The diner will possibly host a TV, and Apple TV, so I plan on using 1-2 ethernet connections to route to this location.
The kitchen will possibly host a TV, and Apple TV, so I plan on using 1-2 ethernet connections to route to this location.
First Floor
There are three rooms upstairs; two bedrooms (one will be used as a study), and bathroom, in the middle of the house are the stairs (between the bedrooms).
As mentioned before, there is a small cupboard above the stairs which could be used to distribute the network.
The bedroom will host a TV, and PS3, and possibly an Apple TV, so I plan on using 2-4 ethernet connections to route to this location.
The bedroom (study) while host an OS X Server, and possibly a TV, and Apple TV, so I plan on using 1-4 ethernet connections to route to this location.
The small cupboard will host an AirPort Extreme as the primary router and likely and ethernet switch.
Other rooms will also host AirPort Extreme(s) / Express(es) as bridge routers (to extend the Wi-Fi).
I am undecided whether to use a star installation on the ground floor, then the same on the first floor (on a per floor basis) or just use a star installation from where I will distribute the network from.
I am also undecided where to use a central switch or use in-room switches and just using 1 ethernet connection to each room.
I would like to use Cat 6 cable for this installation.
The building has brick walls and I can't really run any cables through the walls, so I plan on using the floorboards and getting cable upstairs using the underneath of the stairs.
Also, I'm not sure where I should get any equipment from; I live in the UK and would like to get this as cheap as possible.
I'm open to advice, feedback and suggestions.
Locations & Devices
Ground Floor
First Floor
