Hi,
I am thinking of busying a second Audi A4 Estate, I am quite a long way off being in the position where I a) can afford it and b) need a second car
I realise its a mistake to start looking for "something to do" before even buying the car but I find myself bored and looking for something to do
I want to go for the 2009+ model because of the built in LCD screen. I would like to build a car PC and in the likely event that the car wont come with NAV I would like to install some kind of NAV on the PC and use that - this had the added advantage of being able to play music and have NAV both coming from the PC (same input)
I would use something like this to connect the car PC to the built in LCD screen
http://www.xcarlink.co.uk/product.php?productid=63&cat=4&page=1
Does anyone know if a good linux/windows navigation program that supports voice directions, something hopefully as good as the Tom Tom iPhone App which I currently use?
Is it worth me replacing the built in LCD screen with something else?
