Home hub 3 and btfon / openzone
5 Oct 2012
Hi
I'd like to know how do you find out whether you are subscribed to openzone or not on hh3. Will the router have a btfon led indicator or will it all take place incognito?
Secondly even if it is not activated will the home hub still reserve some bandwidth for btfon? This might be a logical move so that BT customers do not feel there's any point in disabling it. Therefore keeps the btfon network alive
I'm asking because my nephew had hh3 and I gave them my tp link router and noticed a slight speed increase after the switchover. There was no indicators to suggest it was on btfon and the administration page on hh3 did not have anything indicating it nor could I find anywhere to enable or disable btfon
You opt in/out via BT's website. No idea whether thay actually reserve any bandwidth.
Just changing routers (and probably chipsets) is likely to change the sync to some extent.
