- 18 May 2010
Hi,
My Home Hub 3 keeps dropping WiFi connectivity to all devices, the light stays blue but once it does this the devices wont reconnect until the Home Hub is restarted or reset with the button on the back using a pin. After a while it will drop connections again at which point the devices will reconnect until it drops again a few hours later.
I have googled but only come up with resetting as above.
Has anyone else had this issue? Its just started doing this after 3 years without any problems with WiFi connectivity
Thanks
Thanks
