Came home today and booted my PC only to find the Network connection showing a Yellow triangle and being reported as 'Unidentified Public Network' rather than the name I gave it and setting it as home well over a year ago!!
After 10 mins it connected to the internet, but it was still 'Unidentified'
I rebooted... Restarted the router... Even re-pared the TP-Link home plugs... Every time 'Unidentified Public Network' but still able to get on the net!
I found a quick fix on the 7 forums, but I'm worried the problem might be deeper (virus or hardware)
Anyone had this problem?? Found a permanent fix??
Spec:
Windows 7 64bit ultimate
Wired network (Power line)
BT Infinity
Cheers
Sim.
Spec:
BT Infinity
Cheers
Sim.
