Home Made Crisps!
19 Jan 2009
Ilfracombe, N Devon
I had a few potatoes on the way out so I thought I had better use them up, and what better way than home made crisps?
Very simple to make and delicious.
All you'll need is;
Potatoes
Oil
Seasoning (in this recipe I used Salt and pepper, but any mix of herbs and spices to get a flavour you like would work, a few other ideas are Paprika, chilli or BBQ seasoning)
1) First peel you potatoes, and then use a peeler to slice them in to thin pieces.
2) Lay the potatoes on kitchen roll and dry them off.
3)Heat a few centimetres of oil in a frying pan and add the potato slices, turning a few times while browning.
4) When browned, remove them from the pan, and drain off any excess oil.
5)Place in a bowl with more kitchen paper and and add the seasonings, mix them around a bit to get a proper coating.
5) Transfer to a bowl and enjoy! :)
They look good, if a little greasy. You'd need a pretty big fryer to make a bag full though.
You need to keep them separate when you cook them, otherwise they stick together, that's the only trouble with cooking a lot of them in one go.
And they look greasy as I took the picture a few seconds after they came out of the fryer. they dry out after a few minutes :)
Extremely impressive, but I can't help feeling that home-made crisps are much like puff pastry in falling within the 'life is too short' category to make yourself.
That being said, I'd agree with arc@css about going down the 'root' of vegetables instead of potatoes.
