- 24 Jun 2003
So i'm wanting some pointers as for a solution to making a small pc for my home media requirements.
if i was to build a small PC to go in the living room for the purpose of downloading and streaming media using bit torrent and other android APK's
if i install Android as the OS on the media PC will i be able to use an android media player to play any media downloaded ?
Also as for the hardware side of it , would i be able to play 1080p movies without a graphics card , by just using the integrated graphics from an intel CPU , if so what would be the minimum CPU spec?
I want it to use android OS as many of the streaming apps are not available for windows.
I've just had a dig around and found a i7-2600k and 2 x 4gb of DDR3 , would the integrated graphics from that CPU be able to play 1080p movies ok ? and is the 8gb of ddr3 memory enough?
