Hi All,
I’m going to build a home NAS and backup device, but in due course will also want to use as a server for Media, Home security, Router/Firewall, and probably more.
I’ve been reading up about ECC memory and the extra benefits it provides. Sounds like the general advice is, it’s not necessary but is extra security for your data, and if you can afford it, you should use it. Do you agree / disagree with this?
I have a budget of around £350-£400 for CPU/MB/RAM/CASE.
I recently ordered THIS cheap CPU/MB/RAM bundle from AliExpress, but having doubts if it is the right choice for a number of reasons:
1) I have a Ryzen 7 2700X which is unused and would love a new home, and according to THIS page, it supports ECC when used with a X570 board.
2) Looking at THIS comparison it suggests the R7 would outperform the Xeon E5-2650 V4 by a decent margin.
3) Lack of support for cheap Chinese boards I.e manufacturer support, driver support etc
4) Quality & reliability of components
Another factor is that this is going to host multiple HDD’s (intially x4 but possibly up to x8 in the future) I’m most likely going to use an HBA card for additional SATA connections which will use up a PCIe slot, so I’m debating if I should go with an ATX board over an M-ATX board for better expandability options for the future.
So my questions are:
1) Should I...
a) give the AE combo a chance
b) Return the AE combo, look for an X570 board to use with 2700X (for ECC)
c) Return the AE combo, look for a cheaper board like X470, B450, X370, B350, or A320 to use with 2700X (No ECC)
d) Sell the 2700X, return the AE combo, buy an intel CPU (maybe something like THIS) and appropriate MB
e) Something else
2) M-ATX or ATX ? This will then allow me to choose a suitable case.
Any advice or guidance would be most appreciated.
Thanks
X20
1) Should I...
e) Something else
Thanks
X20
