Hi, looking at setting up a home network, currently have virgin superhub which isnt so super!
basically we are looking to use superhub as modem and plug in wireless router and gigabit switch to it. hopefully network it all so each comp can talk to each other and have 1 main unit for all the files and downloading.
now the problem is what is the best way to do all this.
we have :
superhub
tplink 5 port gigabite switch ( will upgrade to more ports as needed)
2 desk top pc's
2 laptops
2 htpc's
yamaha network amp
xbox 360
we plan to have wdtv in each room which doesnt have a pc or htpc
we dont have wireless router yet!
can anyone help us/guide us through doing all this properly maybe even a diagram of how things should be plugged.
many thanks in advance
we have :
superhub
2 desk top pc's
2 laptops
2 htpc's
yamaha network amp
xbox 360
