I'm looking to network up my house, with the idea of streaming media from a server to several locations, and also using the server as a backup solution for the computers located around the house.
Current setup is as follows
1st Floor Office
4 Port Buffalo Wireless Router
PC
PC
Network Laser Printer
All of the above are connected to the router via Cat5e
1st Floor Bedroom
4 Port Switch
Server
PC
HTPC
XBOX 360
In addition to this, I will be requiring to cable upstairs for a single HTPC, and downstairs for an HTPC/XBOX360, and possibly to a kitchen extension scheduled for early next year which will have a small dining area with a TV/HTPC.
So, what would you recommend regards how the network is set up?
1st Floor Office
PC
PC
1st Floor Bedroom
4 Port Switch
Server
PC
HTPC
XBOX 360
- Does the server need to be centrally connected to the router for efficieny?
- Should I simply cable upstairs/downstairs via the router, then use a switch if necessary?
- Will 100mb suffice, or am I going to need gigabit If I am streaming HD media?
