I'm trying to educate myself to put together a home network, do it once well, then hopefully minimal interaction.
The house is prewired was Cat5e to location in a room under stairs so that will be location of router, intend to use ISP (Fritzbox 5780), router mode, with WIfI disabled. Looking at Ubiquiti to provide WiFi AP's as seem best bang for buck.
Any feedback on proposals below would be appreciated.
Cabling
Hardware
Cabling
- For terminations at central hub, each cable to be connected to a keystone, them attached to the faceplate, wall mounting bracket matching the hole size in wall.
- For keystones, I got the following. Seems they require cable provided at 90degree to keystone. Not sure if this will cause difficulty in punching or mounting keystones on faceplate as never done this before.
- Around house, the cabling at points are not terminated. If Ubiquiti Ap's used, then RJ45 plugs, POE switch to power them.
- Understand that the cabling to these points may require specific RJ45 plugs as solid core rather than stranded cable. Haven't looked into that yet in detail.
Hardware
- ISP router used, WiFi disabled.
- 8port POE Switch to power the AP's, peripheral connections to network (house alarm, hue hub etc). Example one below
- Living room has tv, Sky, Xbox, Firestick etc, also main users on tablets, phones here on adjoining open plan room. Was think an in-wall Ubiquiti HD unit here, as has inbuilt switch, also WiFi. Its location will be behind a 42" tv so unsure how effective this will be for other users in room (laptop / phone etc).
- A temporary home office downstairs opposite side of house has another point pre-wired for tv with cat 5e in one corner. WiFi users in office only, maybe a Unifi AP here?
- A 2nd temp home office in bedroom upstairs. Also various Hue lights and plugs etc around home to connect to WiFi.
- Would you think that a 3rd AP needed to get decent WiFi upstairs (2500sq ft house) or trial and error?
