So we're getting our house done and are going to install a new networking system.
The idea is to have a ethernet access point in each room about 8 rooms in total.
So I had a question about the setup and if there are any holes in my plan.
So each room has a ethernet port routed down to a patch panel under the stairs. Each room will connect to the patch panel and each port on the patch panel will connect to a port on a gigabit switch.
The cable will be CAT6 and a 16 port gigabit switch.
On top of that I'll have a wireless access point on each floor (3 in total) for guests and laptop users.
What you guys think?
