Currently undertaking some home renovations so have the opportunity to run network cables in the walls. Total of 4 runs with a maximum length each of 10-20m. I think Cat6a will be the best option, while they won't run next to electrical cables through the whole run they do come close in some points. All cabling will be internal too.
Looking to future proof, is Cat6a the best option? If so are there any 'brands' of cable I should go for, or should I pick up the best value 100m spool I can find? Same with keystones are they all 'the same'?
