Hi all, I could do with a little help configuring my home network.
My current set up is as follows
BT Home Hub
Power Line Adapter model: (TP Link TL-PA211)
Basically the Wifi is rubbish when downstairs. I use a Linksys E4200 at the top of the house which provides great WiFi. To get the internet upstairs I have to connect the Powerline adapter to the BT Home Hub and then to my Linksys E4200 which works.
My Home Server is connected to Linksys E4200 via Lan, access media content is perfect over WiFi.
I want to use the Power Line Adapters for PC2 and PC3 which works great for the internet but I am unable to gain access to my media content.
PC 2 ipconfig ----no access to server
Connection-specific DNS Suffix . : home
IPv4 Address. . . . . . . . . . . : 192.168.1.73
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
PC1 ---working perfectly
IPv4 Address. . . . . . . . . . . : 192.168.0.12
Default Gateway . . . . . . . . . : 192.168.0.1
I assume the problem is caused by the different Default Gateway, clearly something is wrong here. The Powerline adapters are connecting to the BT Home Hub's IP address and not the Linksys E4200.
BT Home Hub
----->Power Line Adapter --->Linksys E4200---->Home Server (Media content)
---->Home WiFi
---->LAN Connection - PC1
----->Power Line Adapter--->PC2
----->Power Line Adapter--->PC3
