Hi guys.
I'm looking to set up a fairly straight forward home network with some traffic going out via VPN. My connection is around 30 down 7 up so nothing special.
The network will consist of a gaming PC, a few laptops and the usual mobile devices. I want QoS such that the gaming pc gets the lowest latency and I want the option for each wireless device to send it's traffic via VPN or via the standard connection (probably via the option to connect to a VPN WiFi or standard wifi). Some ports will always go via VPN.
My intended setup is an bt openreach huawei hg612 3b modem, with a d525 atom pc running pfsense and then a wireless access point.
The modem seems to be universally recommended as the cheap go to and I've just picked up the itx pc on the cheap to try this out. It doesn't have aes-ni but hoping that shouldn't be an issue on a modest 30M connection.
The pc needs a network card. I'd probably go quad port, it must be pci-e x4 and I've heard Intel is the way. Can someone post the exact model number of the best card for this application?
As far as access points go the seems to be lots of good things said about the ubiquiti access points. Is this the right part for my application where I want essentially two networks to connect to, one VPN and one non-vpn? Is this a good option for working with pfsense?
Any help appreciated. Cheers!
