Home Network Help needed!
25 Jan 2006
Gateshead, Newcastle
i want to setup a home network with the following;
3 computers, 2 normal and 1 HTPC
1 internet connection (cable ethernet)
Ethernet harddrive
USB printer.
I dont know what hardware i need to link them all.. help needed... thanks for any replies.
PS: doesnt need to be wireless, all 3 pc's are in the same room..
A Linksys WRT54GS (wireless, but you can turn it off) will connect to the cable modem and do routing - it's probably one of the most stable cable routers around.
It has a 4 port switch, so you can connect your 3 PC's plus NAS drive.
I'd recommend just sharing the USB printer connected to one of the machines if you can - USB print servers are really a bit rubbish and rarely work properly (you can't get status information for example).
