After a few pointers and some clarification before I begin this next week....
I've never had an interest in networks and how they work so I'm starting from scratch. I understand some of the basics and the crimping & punchdown stuff looks easy enough.
Weighing things up, I'll be going for Cat6 (6a is double the price) with 1 or 2 connection points in each room (3 bed house, solid walls and floorboards). A total of 14 runs. The set up will be in the hall, possibly in a small free standing cupboard.
1. I'll be using a switch/hub and no patch panel as there will eventually be a media server added. Apparently this will work as a switch allows cross communication whereas a patch panel does not (and I'd need a switch anyway). Is this correct?
2. I have a 30m run to the building at the end of the garden. External LDPE is best for this (armoured is too expensive) I presume? I think I can bury it but does it need any extra protection?
3. Can I make ethernet cables using the spare Cat6 cable or are they a separate thing?
4. A 16 port switch is enough, 1 of these ports will connect to the router I take it? This one probably
Any other advice? (am sourcing stuff from Netstore Direct)
