Hey,
I've been having some network issues for a while now so the other day I purchased a new router (Netgear Nighthawk R7000). I connected it to my existing Plus Net Hub One from one of its LAN ports to the Netgears WAN port. I disabled all extra features of the Hub One in the hopes of using it just as a modem. Unfortunately this is not possible so now I need to ask you guys some questions:
Do I return the R7000 and get a new router with integrated modem? If so then which would you recommend?
Or
Do I keep the R7000 and get a separate modem? If so then what modem would you recommend?
If I go the separate router and modem route then which router out of the following would you guys recommend as I've actually been looking at them both or would you rather something different?
Would a separate setup be more future proof or is that not correct?
Or
Linksys Velop Dual band 2 pack
Thanks in advance,
Neil
Or
Or
Thanks in advance,
Neil
