By way of background, I live in a rural area which fibre has yet to reach. I have a BT ADSL line which returns <2Mbps and I have a 4G router which returns greater speeds (up to 45Mbps) but is limited to how much I can download per month. Until recently this has not been a viable "all in" solution, but last week I moved to a new provider and data plan that should be sufficient for all of our household needs to the extent that longer term Id like to leave the ADSL connection altogether.
Prior to this new data plan, the 4G connection was only really used to watch TV on demand. All other services were generally linked to the ADSL connection, since, albeit slow, the service being unlimited was more robust and reliable. Linked to the ADSL router and its network I have 3x Sonos speakers in different rooms (via wifi and happy to keep the data provided by the ADSL connection for now), and an NVR with 4 cameras (via cat 6 with static IPs) connected to it via a switch, in addition to a Sky box and Amazon Fire TV. Internet connectivity to the switch is provided by the ADSL connection, so if I am on the wifi network for the ADSL connection, I can view the cameras without issue.
Needless to say, the 4G router has a different IP address and I would like for this new connection to provide the internet connectivity to all the devices connected to the switch. The issue I have is if I simply disconnect the ADSL connection to the switch in favour of the 4G connection, I lose access to viewing the NVR and cameras. Interestingly, it seems the cameras continue to record perfectly (using their static IPs) even when the ADSL router is disconnected from the switch in favour of the 4G router. This is an area of confusion for me since I have devices from 2 different IP ranges attached to the switch, which appear to be functioning fine, albeit that the cameras are not "visible" on the network. If someone is able to explain to me why this is, I would be interested to know?
I fully admit my knowledge of networks is poor. What I would like to do is to be able to view my NVR and cameras with the 4G router providing connectivity to the switch. I realise I could go and re-assign IP addresses for the NVR and all my cameras to the range of my 4G router, but this would be quite a time consuming process. I would be grateful if anyone could advise a more efficient and elegant way so that I can essentially link the IP address ranges for the 2 routers to allow me to view the cameras on the wifi network broadcast by the 4G router.
Thanks for reading.
Thanks for reading.
