Hi All
I'm tempted by a network update. We are currently with Virgin.. the connection is solid, but the wifi is rubbish, and seems to be getting worse, which has been the annoyance factor driving the change. Virgin have been taking the **** on pricing for a while now, and although we have had very few issues, its time to move to fibre i think. I need reliable internet over fast internet, and since virgin has been trouble free, i havent bothered to change it. It is very lacking behind in speed compared to other options.
I have the house fully wired with CAT6. Currently, i'm using the virgin box for router and wifi, then feeding that to my switch, which goes round the house.
Anyway, it looks like i can get fibre at 1650Mbps down, 120Mbps up (i thought it was equal these days?) with Openreach for less (with IDNET) than i'm paying virgin.
That being the case, i'm thinking of getting a "no router" option from the ISP and getting something like the Unify Cloud Gateway Fiber (UCG-fiber), plus an access point. Its possibly a bit overkill, but it should be pretty future proof. i can (i think) use a DAC cable to to connect the SFP+ port from the unify to the mikrotik switch (is there a better way?), use the POE output to the AP, then id have three 2.5GbE ports, which would be handy. It should fit in the bottom slot of the rack with a shelf... just. The UCG-Max would probably be enough to be honest, but the price between the two isnt huge, and id need a POE injector with the Max to power the AP, so that narrows the gap by a tenner ish.
I have ring cameras currently, so i'd probably look to move to unify cameras eventually. The SSD slot should enable that. Though the Ring cameras with lights on them seem better designed for home use than the unify options.
Id likely get the new hardware first, pop the virgin hub into modem mode, get that all working ok, then start looking at moving over to openreach.
i'm not that clued up on networking, but i get by with some reading, once ive figured out what i want to achieve.
Does this seem like a reasonable plan?
Thanks
Thanks
