Home networking help
16 Feb 2010
Southend-On-Sea, Essex
ok so i have connected 2 pcs to the router and 1 is connected wirelessly i want to be able to get files from the other pcs and access them, how can i do this? because i have spent quite a while trying to do it.
Laugh at me all you want but please try and help.
it would depends on what OS is on both of them.
i assume you just have both pcs set to get thier IP address automatically ?
all you really need to do is make sure you enable file sharing on both pcs, its disabled by default, how you do this depends on the OS.
Next you need to setup the folders u want to share on each pc, then you should be able to access them
both pcs are using windows 7 64 bit the laptop is using windows xp i can browse all the xp files not sure how to do it in windows 7
