Home office PC for parents
30 Sep 2004
Scotland
Hi all,
Been out the game for a while so getting to grips with current hardware...
My parents need a new home office PC so I've spec'd this up, do your worst
Corsair Carbide 200R Compact ATX Case - Black - £54.95
Samsung 500GB 850 EVO SSD - £139.99
Team Group Dark 16GB (2x8GB) DDR4 PC-24000C15 3000MHz - £59.99
Gigabyte Z170-Gaming K3 - Intel Core i5 6600K Bundle - £291.98
Super Flower Leadex GOLD 550w Fully Modular 80 Plus Gold - £67.99
Raijintek Aidos Direct Contact CPU Cooler - £12.95
Dell UltraSharp U2515H 25" IPS - £275.99
£903.84
That's a decent spec, but overkill for an office PC.
Unless the CPU/board bundle works out cheaper, I'd get a non-K i5 or even an i3 paired with an H110 DDR4 board.
For a little less, I'd swap out the Dell 25" for a Dell U2412M if they're still available. It's a very nice monitor and has a very clear, sharp picture.
Yeah I thought that, I was being a bit over the top as my dad has zero patience with technology, when it breaks or goes slow it is liable to end up smashed on the patio...
I don't think I want to compromise on the monitor
How about this:
Z170-A Pro Intel Z170 (Socket 1151) DDR4 ATX Motherboard - £82.99
Core i3-6100 3.70GHz (Skylake) Socket LGA1151 Processor - Retail £99.95
£794.80
If you're going to stick with Z170, then that board is fine. You could go with something like this and save a bit. It only has 2 RAM slots for a max of 32GB, but 16GB will be fine for years to come.
Personally I prefer Gigabyte and Asus boards to MSI, but that's just my preference.
3000MHz is a good speed for Skylake. Just be aware that high-profile RAM can interfere with the CPU cooler. Also, the i3 comes with a stock Intel heatsink/fan - it's just the K-series CPUs that don't anymore.
That said, for £13 it's a decent little cooler and should be better than the stock Intel one.
You could still go with an i5 like the 6400 or 6500 - they're still true quad-core, just not as fast as the 6600K.
I would go way cheaper for an office PC. A dual core pentium would be more than enough - My work PC is an old E7500 and is fine (HDD aside - stick with an SSD), and my home PC is a duel core Athlon - still absolutely fine for internet and office stuff.
No need for a Gold rated PSU, nor one with as much as 550w. You'll only draw about 100w.
And the monitor.... I'm no expert on such, but I don't see why your parents need a £275 monitor for a bog standard office PC. Unless either is a hobbyist photographer, get something for about £120.
No need for 3000MHz RAM, H110 motherboards can only run it at 2133MHz.
PSU can be less wattage (doubt you'll pull 100W with this system) and more quality and warranty.
My basket at Overclockers UK:
Total: £680.88
(includes shipping: £0.00)
ITX option. 1440p treat.
