My girlfriend has got two pretty old PCs and wanted me to make one good PC out of them, however all I can scavenge is a 300W PSU, DVD drive, the case, and the HDDs. I also have a AMD Dual Core Althlon II X2 250 3.0GHz from an old build which I plan on using.
I want something quick (so she doesn't get impatient with it) and stable (so I'm not having to fix it all the time). Mainly for word processing, but some simple photo editing, watching DVDs etc as well, plus can support the two monitors.
Current plan is:
Asus M5A88-M AMD 880G (Socket AM3+) DDR3 MicroATX Motherboard
MicroATX, DDR3 and SATAIII so plenty of scope for upgrade
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (KHX1333C9D3B1K2/4G)
Max can use with 32bit Windows, but is it better as 2x2G or 1x4G?
OCZ Agility 3 120GB 2.5" SATA 6Gb/s Solid State Hard Drive (AGT3-25SAT3-120G)
Plenty of space for a boot drive
Thought/suggestions? Will the integrated graphics be enough? Will the PSU be enough?
Thanks in advance,
Current plan is:
Thanks in advance,
