- 1 Sep 2007
- St. Helens & Blackpool
All I do is Play Games, Browse the Web and do a bit of Photoshop, 1 Question Is XP Proffesional worth the extra £30 over Home. (OEM of course)
Or wanting to use Microsoft Remote Desktop as one end must be XP Professional. But in XP Home you can use VNC anyway.For all you need, Home is plenty. You only need Pro if your gonna add the pc to a domain.
Same. If the OP has that PC then Vista should run pretty well.If you are just buying the OS now, why not go with Vista ? At least a little more future proof![]()
any pc magazine telling home users to use pro should be shot
