Home plugs
7 Nov 2011
Hello,
I bought some TP Link 200mbps homeplugs a good while ago. Never seemed to have had any issue with them. Just upgraded to FTTC and noticed that I only get half the speed on my computer as the office computer downstairs. Will this issue most likely be the plugs? Therefore necessitating the buying of faster plugs.
Thanks
Run a cable, far better
But not always practical.
The speeds rated on Home plugs don't really seem to mean much. In very happy with my TP-LINK ones but I get no where near the rated value.
When I was still at my parents house they did a re-wire and the speed basically tripped.
Just avoid TP-Link adaptors as they have disconnection issues.
Powerline adaptors are fine. Apparently they interfere with broadband but I've tested their affect several times and I have found no difference with them in use or not.
I can second this as im using TP-link powerline adapters 500mb ones and get d/c isssues often and have to resync a lot. Bought top end 1200mb devolo powerlines instead. just waiting on them now.
