- 4 Aug 2007
- Wilds of suffolk
Does anyone have a home safe?
If so where is it, and how is it secured to make it very difficult to easily remove?
I am considreing getting one, but issues are:
Where to put it, most easy access places have terrible mounting points (eg plasterboard walls)
Even in the loft it would be attached into breeze block, ie not that strong.
I had considered bolting into a joist, but making the bolts so they would spin from the outside, meaning you would need to access the inside head of the bolt as well as the outside to be able to undo.
Just looking for any options/ issues others may have faced.
Not storing anything massivley valuable but there is a hastle factor of having it in the loft (meaning its less likely to be used regularly. Vs the fact I am struggling to think of any way to secure it well to anything below loft level.
Suppose I could get a rotty and hang it round its neck
