- 9 Sep 2010
Hi there forum fellows,
First of all let me thank you for the wonderful forum, so grateful to everyone involved!
I am looking for recommendations for a USB 3.0 hub, one with 7-10 usb ports.
It has to work with a Macbook pro Retina without interfering with it's Wi-Fi or Bluetooth, as most of the ones I have looked up on Amazon have this problem mentioned by a lot of buyers.
It has to be powered from mains.
It will be good if it has 1 or 2 dedicated charging ports.
It will be good if it's supported by MacOS, but also Windows and Linux.
Budget: ~£30
Any help is greatly appreciated!![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Kind regards,
atkuzmanov
Budget: ~£30
Kind regards,
atkuzmanov
