Hello All,
I’m in the process of studying and then taking my ICND 1 exam for Cisco, to then work my way up to a CCNA, then CCNA in voice and onwards for the certifications just specialising in voice.
To that end I want to setup a home network that I can also use VoIP, practically Cisco and anything that will let me use the router as the ASDL modem, with wifi but most importantly using the standard IOS and hopefully SDM.
I’m just wondering if any one here has done something similar and can recommend a Cisco device and roughly how they went about setting it up, also are you running cisco unified call manager and if you are how did you manage it?
Kind regards,
Shane
Kind regards,
Shane
