I’m looking into setting up a wired network in my home, after getting really fed up with wifi, I just need some advice before buying the parts. I’m getting a company in to run the cables behind walls and terminate them but I will then add the networking hardware.
I think I will need the following, please add anything I’ve forgotten
- 6u network cabinet
- power panel
- 24 port gigabit managed switch with POE - any recommendations? I like the unifi switches although these look expensive but from what I’ve seen get decent reviews.
- cat 6 cable, 305m drum - any dramas better than others or is cheapest also fine?
- rj 45 plugs
- wall plates
thanks!
- power panel
- rj 45 plugs
- wall plates
thanks!
