Homemade Pork Scratching Shelf Life
18 Oct 2002
Nr Colchester, Essex
Something I can't find a definite answer for is how long will homemade scratching keep for in an air tight container? Not really sure how risky they are being they are 99% fat you would assume the risk isn't that large, but there might be small amounts of meat left.
What do you think?
It'll probably last a week or two before it starts to go soft, longer if you have one of those vacuum seal things. You probably won't have any problems with bacteria or mould, the deep frying dries them out pretty thoroughly. I'd imagine the fat will probably go rancid after a few weeks though.
It's pretty simple really. It has always annoyed me that when I make pulled pork I have the skin left over, I don't like wasting things more so when it's meat.
This isn't the "correct" way but I have had good results, and deep frying them is too much hassle, and they spit ridiculous amounts of fat everywhere.
1) Take your skin, it's probably already scored, but I tend to make deep cuts where you will chop it up anyway.
2) You then need to salt it, you can use plain salt or I have some that I added toasted fennel seeds to. Using large salt crystals is quite good as you can brush the majority off before roasting, it will be pretty salty anyway.
3) Leave it in the fridge for 2/3 days to dry out.
4) Pat the skin dry and remove any excess salt. Chop the skin up into bite sized pieces and place them on a baking tray.
5) Set oven to 200C and whack them in. You are basically cooking them until they are golden brown and curled up, you need to keep an eye on them and drain off the fat regularly as it renders.
6) As a final step just before they are done you can sprinkle them in a spice mix of your choosing give them a toss and leave them in long enough just to toast the spice (1-2mins).
As I say that isn't how you are really supposed to do it, and they are on the crispy side but everyone at work kept coming back for more, so they can't be that bad!
Ps. Remember to keep the fat for roasting potatoes etc!
My local morrisons used to sell the skin, not sure if they still do but it was very cheap
When I make scratchings i score the skin, place in boiling water for a few seconds (to open up the cuts), pat dry, rub in salt then place on a rack on a baking tray in a hot oven
Sometimes I will just cut the skin into strips and fry them in a frying pan with just enough oil
Photo of the last batch:
Is the Tom Kerridge recipe written down anywhere? I can't really watch the TV show here in work but I'm interested to see the recipe :)
Yep, I think it's in his book! I also think that I got it for Christmas (got so much cooking/baking bits I can't remember) so I'll have a look when I get home this evening.
Edit: In fact this is the recipe but not in full: here
Thanks for the link. I'll check it out later :)
The actual recipe is:
1Kg pork skin (preferably from the loin)
1 tablespoon salt
200ml white wine vinegar
Oven at 180 (gas mark 4).
Cut pork into 7cm pieces.
place them in a large non-metallic bowl, add the salt and vinegar, mix together thoroughly and leave to stand for 1-2 minutes.
Transfer pork skin pieces to wire rack in a roasting tray.
Place the tray in the oven and roast for 10-15 minutes until crispy (they may take longer).
If you have good self-control, leave to cool completely before eating.
