Homepage dosent work - help
5 Dec 2006
Hi,
Everytime i open IE7 the homepage dosent automatically load and THIS error page is displayed instead.
However when i click the "home" icon in the toolbar, google.co.uk, which i've set as the homepage, loads up fine.
What's stopping IE7 from autoloading the homepage on startup and how can i fix this.
Thanks.
EDIT: forgot to mention; its a brand new install of vista 64 bit with sp1. Installed it just today after i upgraded to 4GB ram.
Try this, go to Registry Editor
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\MAIN
Set Start Page to whatever you want.
Thanks for the reply, i did as you said but still the same thing happens.
The page that it tries to load at start-up is this:
http://go.microsoft.com/fwlink/?LinkId=76277
but then it tries to find the page, but the page dosent exist, so then this error page loads up:
http://www.msn.com/404.aspx?aspxerrorpath=/runonce2.aspx
It's like Microsoft has programmed IE7, so that the first time you load it this page comes up: http://go.microsoft.com/fwlink/?LinkId=76277, Like a intro to IE7. But since that page dosent exist anymore it keeps trying to load that page everytime i open IE7.
