Homepage Keeps Changing
20 Jan 2004
jsut reinstalled windows on my laptop and the homepage in internet explorer wont change, it keeps going back to the manufacturers (acer) website, how can i sto this??
Ok, then so when you say it "wont change" does it stay the same in the options?
Or does it re-generate back to what it was, little more info wouldnt go a miss. :)
yeah it does, you click ok, close the options window then when you go back in its back to , global.acer.com or whatever. it doesnt do this in firefox, which i use, but i sometimes use ie and its bugging me!
Start - Run - regedit
Open HKEY USERS
Open S-1-5-21-796845957-412668190-839522115-1004 (or similar, below S-1-5-20_Classes)
Software
Microsoft
Internet Explorer
Click Main once.
Then on the right side, look for START PAGE.
Double click START PAGE and type in what you want.
One thing you could do, would be to reboot and use F8 and load up in Safe mode.
That way you could login as Admin and find the homepage entry in the registry as Kerplunk detailed above.
At least in safe mode, hopefully there should not be any possible sneaky program in the background stopping you from changing the homepage.
EDIT: Oh there is one solution that would be 100% effective.... try Firefox or Opera ;)
utah said:
ok ill try that, its obviously somethng pesky acer have put on pc
It's worth maybe searching acer's support site. I'm afraid i'm not that familiar with Acer PCs/Laptops so i'm not sure why you can't change it. But it's obvious they have got some program running that's stopping you changing it.
If you still have no luck trying safe mode, download a program called Hijackthis and run it with the report option. Once it's run it'll open notepad and you can copy the entire document and paste it into the box on the http://www.hijackthis.de website, which will look at the file and check your settings.
Good luck, let us know any outcome :)
was about to suggest this..
get it from merijin site
There are certain parts of the registry that users (even admins) can't edit due to the way Windows sets the permissions on them. Seems odd that a manufacturer should set up an Internet Explirer key this way, but I guess they could have. Just needs fiddling with the offending registry key's security settings (which you can do in XP Pro without going into Safe Mode, but for XP Home you may have to).
I'll leave someone else to explain if this is the case because I don't fancy giving instructions at 2.43am and then finding out I've got them wrong and broken something.
