Homeplug help
24 Feb 2004
St.Andrews
Hey,
Just been looking to move the position of the router due to a better connection at the master socket only to find that it means a network cable lying on the floor/keeping the door open.
Our existing cabled solution is through the wall behind a very large bookcase and the hole isn't big enough to get an extra cable through so we have started looking at home plugs.
What exactly do we need to make that work? Do we need a pair for each connection we wish to make or will one plugged into the router & one for each extra device be OK?
Cheers :)
One for the router, and one for each extra device. The homeplug on the router will communicate with any other homeplugs on the same electrical curcuit.
