Homeplug powerline Noise ?
1 Nov 2004
My homeplugs make a high pitched drone is that normal or can you get silent ones as there is no way i can use the ones i've just bought for my bedroom. :(
I'm running comtrend 200Mbs and they sound like a telephone modem they make a high pitch ringing noise when first plugged in and when connected they make a constant drone which is a shame as they connect across the house at 160mbs.
sidethink what model are you using and do the plugs make any noise at all ever as i plan on using them in my bedroom and any hum or drone will drive me nutz.
