So I decided to move the wireless router to a more central area of the house for better signal strength. I basically extended the CAT5 cable long enough so the router could be relocated but I seem to have created a weird problem.
The problem is, my homeplugs are no longer working, in a sense that the router doesn't seem to be giving IP addresses to any devices which connect to the homeplugs.
DHCP is turned on with the router and I have also tried to manually assign IP's to devices connected but it still doesn't work.
I'm not sure why it would suddenly start doing this as all i did was run a longer CAT5 cable from the virgin media super hub(modem mode) to the router.
Does anyone have any ideas at all?
The router is a Dlink DIR615 by the way.
