HomePLUG Issues & new Super Hub from Virgin
Hi,
I've been with Virgin media for years now and rarely have any problems with them so I am generally happy.
I ran with an older modem with a Linksys router supplying both wireless and a homeport network.
On Friday I had some serious speed issues and couldn't get a connection on my main PC higher than a 1M download.
An engineer was called and arrived today. He has replaced the old modem with a new 'super hub' (N series) and we have established that through testing hardwired lap tops and my connected (homeport) PC that my laptop gets speeds of 18meg both connected wired and wirelss (using speedtest.net) whereas my PC only gets 5megs.
The Engineer suggests that the homeport probably needs upgrading to a newer one that is N series compatible. But I am unsure of whether to spend the money or not.
Clearly 5meg is unacceptable, despite it being the same before he changed it all around(cant believe I never tested it before).
I have an old wireless PCI card, but it is a Linksys-G, which I assume means G series.
I also have my PS3 linked up through the homeport network.
My Laptop gets wirelss speeds of 18m when sitting ontop of my PC, so I know range isn't an issue.
What should I do?
Purchase more homeport things (N series compatible) or just go full wireless by purchasing an N series wireless card?
Is the playstation wireless? If so, is it easy to setup?
Post is a bit messy and lots of questions, so I apoligse for that.
Regards
Lee
Hi,
What should I do?
Regards
Lee
