Honeywell doorbell problem
5 Oct 2006
Cardiff
My previous Friedland wireless doorbell failed after 5 years of good service.
I bought a Honeywell activlink doorbell as a replacement.
The setup is:
Doorbell push button - cr2032 battery
Mains receiver in living room
4x AA battery portable receiver in rear extension.
This worked faultlessly for 2 months without a hitch, I then noticed 2 beeps after the usual chime which happened for around a week, indicating the door push battery was low. I checked it with a multimeter and registered 2.7v, low but not dead. Changed the battery and things were back to normal... for 2 days, until that battery died too.
I'm now on my 4th cr2032 battery within 2 weeks and it's driving me crazy. I don't understand what could be causing it. The receivers don't ever go off phantomly, so I assume the button isn't being fake pressed.
The issue seems to correlate with putting the Christmas decs up, though I have a technical mind and don't really see how they could cause the battery to drain in the push button.
Any ideas or should I push for replacement?
I think you will find it's Father Xmas going round checking all door bell ready for tomorrow - will be ok after tomorrow.
I have a Byron one with three extension bells and two get through batteries like no tomorrow - C & D type got to point I don't bother now. Just rely on one in lounge and good thump as they can't hear any bell when button is pushed.
One thing - is your door bell push lit - I wired one to a big battery at old house and it kept going flat - took me a while to realise it lit up - just cut led wire.
Where did you get the batteries from? There are a lot of bad fake batteries around which don't last, as I've found out to my cost with remotes etc.
First 2 came from dead motherboards (3v registered on the meter).
The new one i bought 3 days ago from the post office, Maxell branded is now dead too,
