hori onyx+ vs nacon asymmetric
1 Jul 2020
Does anyone use either of these? Can they recommend them?
I`ve read some reports of lag for both and other people say there isn't any....
Made the switch to PS4 after many years of xbox and can`t stand the control layout (mainly thumbsticks)
I know there are some more expensive options but I don`t really want to be spending £100+ just on a controller.
I have the Nacon Revolution 2 pro and it's a great controller. Admittedly it is close to £100 to buy.
Ye I did look at that one as well as an option, i`m just not sure on the fact it is wired...can you turn the ps4 on and off with it? Can get a refurbed one on ebay for £42!
You can't turn the PS4 on with it but you can turn it off with it. Bit strange really :confused:
That does look decent actually. I tried the nacon asymmetric and really didnt like the triggers on it so ended up taking it back.
Do you notice any input lag with that controller?
No input lag that I can feel. Just be aware that the first one I got refused to connect so I contacted the company and they sent another out for free which did work.
