Horizontal Cases for ATX, SLI and good cooling.
20 Oct 2010
Scotland, My home.
There are plenty of horizontal case but i cant seem to find a good one what will fit a large cpu cooler and SLI. I dont really care about the size aslong as its not 800D size but horizontally ofc.
Currently using a lancool k62 and i want something like that but i want the drive bays to be horizontal and HD cages. Could this be a good excuse to get an hacksaw, files and a lot of self tapping screws?
i cant put the case on its side just like that as my dvd drive isnt really...good, cds fall out even when its the flat. i use it a lot.
I would either recomend building your own for 100% satisfaction, or heavly modding a case that fits your criteria. Might want to check out the Silverstone RVO2/FT02 the RVO2 will have horizontal hard-drive mounting when you put the case on its side (in its own HD-Cage too). And with there unique layout they can work fine horizontal (with the clear sidepanel faceing up), maybe an Antec 1200 could do it with some modding too. You will allmost certainly need to mod any atx 'tower' for horizontal drive bay mounting afaik.
Hope that helps :)
