Horizontal Flickering
20 Sep 2005
Didn't know what section to put this into (graphics cards? home cinema? monitors? general discussion?) so decided to stick it in here!
Basically i have a dual setup with a 20" viewsonic monitor and a 32" samsung TV in clone mode (same image on both screens). I have had it setup like this for few years with no problems.
Recently i upgraded my gfx card to a gtx460, and since doing this i have noticed a horizontal flickering line down my tv when playing movies/tv shows from pc to tv. It's like a single line that moves slowly from top of screen to bottom then repeats. It doesn't happen when at desktop/windows/browsing etc, only when playing media (films/tv shows).
It also doesn't happen when using my ps3 on my tv, or when watching cable tv, only when the tv is in pc mode. I have tried 4 different media players to make sure it wasn't a problem with windows media player.
I'm seriously confused. The fact it only happens on my tv and not the monitor would suggest it's a problem with the tv. But then the fact it doesn't happen when using ps3/cable tv/and at desktop/browsing etc would suggest the tv doesn't have an inherent problem. :confused::confused:
Is there any possible setting that would cause a problem playing back media that wouldn't be evident at desktop etc?
Cheers for any thoughts/input.
Tried a different cable from the PC to TV? Is it only happening when you watch movies/tv from the PC? Strange that it happens...
It sounds like a pulldown issue from 24fps to 60hz or whatever your gfx card output to your tv is set at.
Change the refresh rate to 24hz in windows for the 2nd monitor (tv) output.
