- 11 May 2007
Hi
I have a 2wire modem / router 2700HGV from BT. I'm wondering if I should have it horizontal or vertical for best signal. We have a 3 storey house with the router on the ground floor. We want the signal to go as high as possible. The only people that use wireless on the ground floor will be in the same room as the router.
Also, is it correct that the signal can be boosted by changing a parameter in the router menu?
Thanks
Pete
Thanks
Pete
