Horizontal tube res?
11 Jul 2011
Abertillery - S.Wales
Can you mount them side ways?
Reason being, my tubing lines up perfectly at the front and back of the case for it to fit?
If I had to mount it vertically, I would need to either re-plan my entire loop, or extend the pipes which would look messy as.
Thanks
Is there any particular way to find out?
Like are the ports in a certain configuration, or would just be a hope for the best situation?
I tried with a phobya balancer res and couldn't get it to bleed for love nor money.
There are a few builds floating around on here that do use a horizontal res though.
Well I can dismount it and lay it semi vertically to bleed the system, thats no problem, just thinking more the flow.
