- 19 Aug 2010
hi,
I'm having an awful problem with my rig and it's beyond my technical ability to get to the bottom of it so i'm running out of ideas and was hoping you could offer some suggestions and advice.
I put together a new PC at the start of the year with the following components:
Radeon HD5850
Fractal Design R2 PSU (650w)
Gigabyte GA-790FXTA-UD5 (Socket AM3) Motherboard
AMD Phenom II X4 Quad Core 955
samsung 2TB Hard drive
Ballistix 240-pin DIMM, DDR3 PC3-12800 memory
Sony DVD drive
Windows 7 64 bit
It was fine for the first three months or so (apart from a windows 7 problem with restarting a pc from sleep mode and large hard drives causing a BSOD but a hotfix appeares to have fixed that) but then it started turning itself off (the power was turning off rather than BSODing or shutting down).
This gradually got worse and more frequent and then it stopped working completely.
I got the PSU replaced and it started working again but the same thing happened with it except it stopped working completely after just 5 days (so it didn't gradually get worse this time it just went).
The gfx card requires a 500w PSU (although the psu isn't listed in the certified list on AMD's website) so a 650w supply should be adequate (so I don't think it's trying to suck too much power through and blowing?). Looking at the total amperage on the 12V rail, the requirement is 40A and the PSU provides 50A so i'm not sure if that's likely to be a problem (?).
I don't think it's an overheating issue as the PSU is cold to the touch when running and I've got both sides of my case off to prevent air flow issues.
My only other guess is that there is a problem with the rig and the motherboard installation causing a short somewhere - Once I've got a replacement psu I'll be taking out all the components and trying to run the rig on top of the mother board box.
Does anyone else have any suggestions about how I can track down the problem and fix this asap? Is it possible it's a broken component somewhere? Should I be looking into getting other items replaced?
I've not got a lot of money and don't have another rig to test components in although I've been offered a cheap gfx card to try and test that against my ati one.
If anyone has got any other suggestions please let me know thanks.
Allan
Radeon HD5850
Sony DVD drive
Windows 7 64 bit
Allan
